| | | Forums66 Topics128,056 Posts1,055,800 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | This issue started 2 days ago, a day after I lowered the rearend. My guess is that there is an issue the Rochester carburetor.
The truck runs w the choke on, if turn the choke off it sputters and dies. When I hit the gas, it jerks like it is getting speratic fuel off and on. Once I am up to speed in any gear there is no issue.
Any suggestions? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "day after I lowered the rear end" might investigate how much that changed the float level
Bill | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Park it facing uphill and see if it runs right. I had a similar issue with a Carter YF after a rebuild. Turns out a check ball came out of the accelerator pump assembly and ended up in the bottom of the bowl. I was able to drive it home with the throttle cable pulled out to about 1000 rpms. Will yours run with the throttle cable pulled out some? If not, you may have a vacuum leak. I fart every morning before the sun rises, but I don't think that is what causes the sun to rise. It might be a coincidence.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Where is the accelerator pump located and how do I check it. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I replaced the fuel filter w no positive results. I'm strongly leaning towards a carb issue. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have you leaned far enough to check the float level?
Bill | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | How do I check the float level? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, it sounds like maybe you take the truck to a mechanic, but you might try digging out the shop manual and study the section about carburetors - you could even buy a rebuild kit and get some hands on learning experience Bill | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | It limped in to work today, finally dies 1 block from the office. It wont fire up any more. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Does sound like a fuel issue. When you lowered the rear end not only did you change the angle of the carb you also moved fuel away or closer to the pickup point in the tank. Take the fuel line off the carb and point it down toward the ground while someone cranks the engine. If fuel flows freely it is probably the carb. If fuel doesn't flow it is a pump or line issue.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I just talked to Tom Langdon, he said its probably dirt in the carb, which makes sense. I will have to take the idler screw out and check for any fuel or dirt. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Remove the fuel line from the fuel pump on the inlet side to check for free flow coming from the tank. If you have flow from the tank, reattach the fuel line and remove the line at the carburetor and turn over the engine with the starter (ignition off) catching the fuel in a bottle. If you have good flow, teach yourself how to rebuild a carburetor. They are not very complicated. When you are done and it runs like new, you can brag to folks you don't even know.
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | If you had a fuel filter installed, why would it be dirt in the carburetor?
Those who frequent these forums know the Rochester B is certainly not my favorite carburetor; carburetors (even Rochester B's) fail over 1000's of miles or a couple of years.
On the other hand, ignition systems fail from instantaneously to over a period of days.
Yes, it MAY be the carburetor, but I would investigate the ignition system first. A perfect carburetor will not run an engine with a defective ignition.
And as Carl is suggesting, you may have a fuel delivery issue (fuel pump diaphragms don't care for ethanol fuel).
Try filling the carburetor with fuel through the bowl vent. Then try to start the engine. If it fires, check the fuel pump. If it doesn't fire, try pouring a tablespoon of fuel into the throat of the carburetor; then close the choke and try to start.
If it fires with the fuel down the throat, but not with filling the carb, then its time to rebuild the carb.
If it doesn't fire either time, its time to overhaul the ignition system.
Jon. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I was way off. Ends up it was the points in the rotor. I get Thunderbolt in Houston didn't check them when they rebuilt the engine. Disappointing. | | |
