4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
Is the tail light wiring grounded by the tail light assembly screws that hold the bezals to the body? I noticed the lights flicker when I tighten the screws.
Yes.
We all fight the rust but, a little bare metal between the bezel and the body is a good thing. The light will do strange things as amperage increases with a poor (high resistance) ground, such as when the tail light AND turn signal operating at the same time; the tail light filament will dim and the turn signal filament will barely glow.
Good luck
Mikey
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
Also the bed was originally grounded to the frame by the mounting bolts which have had 50+ years to corrode. I recommend a ground strap from frame to bed.
Thank you for your replies.
Shawn
