7 members (Wayne67vert, Shaffer's1950, treegrower, TexasFarmTruck, Otto Skorzeny, Pre '68 Dave, 1 invisible), 74 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
I am looking ahead to pin striping my wheels and thought I could make an initial stripe with a sharpie for a guide and then pin stripe over the marker. I would do this while spinning the wheel by hand. The marker would be dry when I did the striping, has anyone had experience painting over marker?
Joe
1955 First Series 3100
DO NOT try this!!!!!
The Sharpie/marker WILL bleed through ….. I used a three stage
pearl paint…. it bled through all three layers….!
Do NOT try this!
It will bleed through all topcoats…..
[quote=Squire]DO NOT try this!!!!!
Thanks for responding Red, I had no idea.
Joe
I just 'quoted' squires opinion out of the black hole .... my thought is if you can use a sharpie to make a guide line, why not use the same technique with a small paint brush? or better, use one of those wheeled striping tools, they come with guide bars, worked well enough for me
There are pinstriping pencils available that claim you can paint right over without harm to the finish. Stabilo is the one that is mentioned most frequently.
3M also sells a fine line tape that is available with pre-cut sections that peel out and used as stencils. Should have enough flex and give to work on a wheel to pinstripe. Have also heard that mounting the wheel on a hub horizontally so that the wheel can spin, get the wheel and apply paint from a brush. The last thing I striped took a while to get the touch (and a fair amount of scotch)on the brush (loading, position, and getting the line width just right) before I had the knack. Prepare to practice and make some mistakes.
Now if I stripe anything that has to be dead on, I use a stencil. The stripe turns out just perfect. No variation in width or thickness.
I've had some success over the years using " Killz " primer. It seems able to seal all sorts of markers - sharpie, metal markers, wood crayons, etc., but.....why chance it. As previous suggestions, I'd try a small pin stripping brush
1940 Chevy KC 1/2-Ton
