2 members (Brian Moore, Wickedbass), 67 guests, and 4 robots.
Topics128,029
Posts1,055,416
Members48,422
#98572 12/21/2006 3:44 AM
I'm having trouble removing my light switch at the back of dash -- got the switch itself off. Following the manual instructions it says 'remove the ferrule retaining nut with the appropriate tool' but where exactly is the ferrule nut? and what is the appropriate tool? The nut has to be holding everything in place but it's hard to see back there and I dont want to force anything and end up breaking something. Everything is old and hard to get loose. Anyone know how it comes apart? Thanks.
#98573 12/21/2006 3:51 AM
The ferrule nut is the peice that is directly behind the the switch knob on the dash. It requires a special spanner to remove it, but I find that a pair of fine needle nose or snap ring pliers works equally as well. Once it has been removed, the switch will come out easily.
Bill Burmeister
#98574 12/21/2006 3:51 AM
it's not 'back there' grin the ferrule is the chrome piece on the face of the dash, which prolly has a couple of small 'nicks' in it that can be pushed with a blunt screwdriver tip to unthread it - it's like a screw that goes into the front of the switch - hafta remove the knob/shaft first
#98575 12/21/2006 3:52 AM
I
I Offline
After you have removed the knob and its shaft, the nut in the thing left sticking out of the dash. It screws into the front of the light switch, though the dash panel. The shaft and knob come out by pulling it towards you and pushing the little button on the bottom of the switch. Some times you have to work it in and out a little to get it to come free.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#98576 12/21/2006 11:02 PM
Thanks guys, I did it -- when you know how it goes it's easy - when you dont know it can be a b----. I took out the dash gauges and and light cluster unit -- took the speedometer apart. Everything seemed to work ok. The only thing I think might not be working right is the little hair spring that keeps the needle at zero and lets it move smoothly when it works right. When I put it back in it worked better but not smoothly enough to be accurate. I know there are places that repair old meters but I think I'll go with new gauges and wiring to replace the old idiot lights. I have read on here that dolphin gauges and EZ wiring are a good way to go. I'm tired of not knowing how much gas I have left or how fast I'm going.
This forum is the best...
