| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I replaced the 216 in my 53 3\4 ton with a 54 235. I hooked up the throttle linkage using the same two rods that were on the 216. it is about an inch too long. both rods have been modified. does anyone have the lengths of the two rods? is the pivot different for a 235?
thanks rolf
1963 c10 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you use the forward position on the 235 block for the pivot than the 216 linkage should attach without any modification.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i checked, it is on the fwd pivot. i'll have to see if i can find one.
rolf
1963 c10 | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Pull your accelerator pedal to full throttle, pull your carb linkage to full throttle, measure the distance your acc pedal goes past your card linkage. Remove throttle linkage and take that amount out of the small side of linkage, weld the two pieces back together and that will take care of your problem. I had same situation last week and working fine now. Good Luck. Caution: be sure you have the curved piece at the right angle b 4 welding. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 |
1963 c10 | | |
