| | | Forums66 Topics128,123 Posts1,056,653 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey All
Im adding a lot of aux things to my 46 2 ton 5 cab lights rear spot light 2nd tail light bed lights heater motors turn signals
the truck is 12v with a generator with external voltage regulator.
Obviously having 1 fuse for the whole thing is kind of crazy (the one in the light switch).
Should I be running an aux fuse box and keep the original wiring harness or go full monty and buy a completely different harness.
I would prefer to use cloth wire just to keep that vintage look, the hot rod wiring harnesses out there arent that.
Anybody out there have any solutions? What are people running in their old trucks?
any help would be fantastic
thanks in advance
jay | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can use an original type harness and add a fuse panel, available from any FLAPS, that is powered with a 10 ga wire direct from the ammeter, battery, or regulator .... most of that stuff doesn't add any real load, the lights are really already taken care of
Bill | | |
