7 members (Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, Phak1, 1 invisible), 44 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#984017 11/06/2013 9:50 AM
I know an MII ifs will drop a 3100's ride height at least a couple of inches. Is there any combination of spring, block and shock that can get it to ride near stock height?
check with fatman fab. i think he builds a crossmember for stock ride height. i put lowering spindles and springs on my 36 to get it to set as low as i wanted it to look
that's a myth. MII will only drop the ride height if you install it to drop the height. you can install it to stock height if done properly. done it more than once. but most are installed lower as per preference.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
The situation is a frame with a Heidts crossmember already welded in. I'm wondering what can be done with that to keep it from getting too low.
MII ride height is determined by the crossmember placement. you my be able to use adjustable coil overs to gain 1/2 to 3/4 inch.
mock your front end up to see how it sits currently and go from there.got any pics?
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
I have a MII front end in a different application and the instructions were very specific. The lower control arms are supposed to be as near parallel to the ground when parked as possible in order for the suspension to work right (and it sure does).
Kind of hokey, but you could also run a taller tire. Also anything to raise the lower coil spring perch would do it, but too much and you would mess with suspension travel and camber.
R-Bo
1966 GMC 305V6 in the family
