BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,781 Posts1,039,301 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | I am looking for the size of a plug for the capillary tube sending unit on a 1954 235 head. I am replacing my gauges. I am also looking for help on adjusting my rocker arms, I just put the head back on following a complete valve rebuild. Any help is gratly appreciated.
"If you're not living on the edge, you're taking up too much space. Life is short, eat desert first."
| | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | Joined: Sep 2009 Posts: 123 'Bolter | 'Bolter Joined: Sep 2009 Posts: 123 | I was going to suggest the same tech tip but DADS50 beat me to it. I used that tech tip on my 235 and all worked out fine.
| | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | Love this forum! Thanks for such a quick response, DAD50. Now I can get the valves adjusted and the plug in place. Can't wait to get her back on the road.
She's a 1950 3100 refrigerator white with a 1954 235 and a muncie 21 4-speed.
| | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | I became very familiar with that thread size when I was adapting it for and electric sender. I also have a 54 235.
pre68dave helped me with the info.
| | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | DADS50, I am curious, how did you end up adapting it for a sending unit?
| | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | Ended up having to make an adapter ...pic... Ran a stock die nut on a 3/8npt x 1/8npt pipe adapter. No leaks........yet | | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | Ok anyone, I have a new question for the same thing. The capillary tube fits into the water jacket against a lip or flange. The nut tightens down to the flange on the capillary tube making the fitting water tight (I assume). Can I just run a 5/8" -18 1/2 " bolt down and use permatex on the bolt to make this a water tight fitting or plug? Actually, the head on the bolt won't torque tight down on the head as the 1/2" is too long, so it's really just threads I am guessing.
| | | | Joined: Oct 2006 Posts: 1,847 'Bolter | 'Bolter Joined: Oct 2006 Posts: 1,847 | you can get a 5/8"-18 oil drain plug and a copper washer. ran mine like that for a couple of years. Or if you make the end of the bolt pretty much perfectly square with the axis of the bolt, (I.E. turn it on a lathe or very, very carefully on a grinder) then put a copper washer underneath between the bolt and the shoulder in the block. I wouldn't just put in a bolt as the ends of bolts aren't really too well finished. Either way would work well. I am pretty sure I wouldn't trust permatex in that situation, it was never intended to perform that kind of service. | | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | Thanks for the suggestion, sounds like it should work well.
| | | | Joined: Aug 2002 Posts: 28 New Guy | New Guy Joined: Aug 2002 Posts: 28 | Hey brokenhead, Thanks for the idea of the 5/8"-18 oil drain plug and copper washer-it works great. Now I just have to figure out why I am getting a coolant leak by the head gasket on number 3 piston. Just filled the radiator up and was turning the engine by hand to do the valve adjustment and a very small leak started. I rechecked my head bolt torque and it is correct.It's coming out on the side by the manifold. Just finished a valve job and reinstalling everything, too. Challenges...oh well.
