0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Would someone be able to give me the OD of the flat washer that sits against the exterior of the firewall for the v rod support of a 46' Chevrolet? Thank you. Jim- | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Mine is 15/16 OD. What I can't tell you is if it is OEM. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | On my 41, the washers both inside and out were 1.25 OD. I have scrapped others and they were the same so I trust it to be stock. | | |
