3 members (Otto Skorzeny, farmallb, rick46ia), 81 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#983371 11/03/2013 5:56 AM
So I've been looking around for a 400 CFM AFB to add to the upcoming build of the 261 and I've realized they are kind of hard to find. A friend of mine has an AFB laying around off a Buick but the model number doesn't have a CFM rating. After doing some digging, I came up with this, its a 4331s Buick carb info the info that I can find about the 9400 AFB says the throttle bores and the primary and secondary Venturi are the same size as the 4331s. Would it be a safe assumption that this carb flows at about 400 CFM? Its for a 340 V8 but only 400 CFM seems a little anemic to me for that displacement.
47bolter #983433 11/03/2013 5:18 PM
H Online: Content
A 340 cubic inch engine at 4,000 RPM operating at 100% volumetric efficiency (impossible) is moving 393 cubic feet of air a minute. A more realistic volumetric efficiency for a street engine without extensive camshaft, valve, and port modifications will be 85%-90%, about 354 CFM max. The 400 CFM carb sounds about right unless you're going for valve-floating speeds.
Edit: The 261 at 4,000 will flow about 270 CFM, so the AFB will be significantly over-carbureting it unless you're planning to run at or near full throttle all the time. A Holley #7448 300 CFM 2-barrel would be a lot more appropriate for a 261 engine. We ran 350 Chevy engines to 6,000-6,200 RPM on the round track with the Holley 2 BBL, but it acted like a restrictor plate at those speeds- - - -manifold vacuum started building up and torque dropped off near the end of the straightaway.
47bolter #983573 11/04/2013 6:58 AM
Thanks for the quick answer. I'm truly up in the air on how to carb this motor. I know some guys have had luck with the 390 Holley 4 barrel on similar sized sixes but I haven't seen a ton of people on this site using them or the AFB probably because of over carbureting the motor. I like the idea of a 2 or 4 barrel rather than running a multi-carb setup. I was figuring the AFB would run around a little under half its CFM rating before the secondaries start to open due to the smaller primaries, but I might yield to your real world experience. Any other tips or tricks that come to building a warmed up 261 would be much appreciated.
