| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | [IMG] http://pic100.picturetrail.com/VOL1061/3611363/16876743/407893478.jpg[/IMG] Rear fender plate obviously for running board, but is it necessary or would backed up bolts do? I haven't found replacements without buying a complete corner section. I could cut one, but wonder if my time is worth it in the long run.
Drew
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | As long as no one uses the step to load heavy stuff in the bed I see no problem... and repairing the distortion that could be caused by straining the metal as opposed to fabbing up a backing plate would only be about three times as long...
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | As long as no one uses the step to load heavy stuff in the bed I see no problem... and repairing the distortion that could be caused by straining the metal as opposed to fabbing up a backing plate would only be about three times as long...  LOL. Good point.
Drew
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I would fab up the reinforcement plates (and make them thicker than stock) and weld them on. There is a lot of stress here due to the fact that the running boards are mounted solid to the sturdy brackets that are riveted to the frame, while the rear fender is mounted to the bed which is mounted in a few locations on small wooden blocks which allows movement. All of the ADs I have worked on have wollered-out (Yes, that is a word where I come from, spell check be damned.) holes in this location. You need as much support in this area as you can come up with.
