3 members (jay d, Southerntruck, 1 invisible),
168
Mod | | | Forums66 Topics128,281 Posts1,058,464 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Ok. As some have read I am rebuilding a '53 in Italy. I just torqued down the crankshaft caps (100-110 ft lbs), as well as the connecting rods bolts (50 ft lbs).
I failed to notice that my EU purchased torque wrench is in Newtons. So, I used 110 Newton measurement, which is (according to the chart) app. 80 ft lbs.
I got it all sealed up nicely, oil pan on, and started mounting to other items on the engine (which is on an engine stand)
SO MY QUESTION: should I drop the oil pan, and re-torque the bolts, or would you leave it alone? Is there a real possibility that the bolts will back off and cause damage to the engine.
Thanks.
Steven
1953 3100
Melbourne, FL Veteran
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | better safe than sorry. I do not know it will affect oil pressure or not. I would feel sick if something happened and I remember that I did not torque it properly. I would love to hear what other people say
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Drop the pan and re-torque it! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I think you are a little high on the rods. I haven't looked it up but I think they are 45 ft lbs tops. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If it were mine I would drop the oil pan, loosen the rod nuts and main cap bolts and re-torque them to the proper spec. | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Thanks guys. I guess a proper job is just that. I'll learn to wear my reading glasses next time.
1953 3100
