| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98153 11/19/2006 8:36 PM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | I'm wiring my truck from scratch and want to have one set of tail lights, no seperate lights for blinkers. Can someone explain how to wire the brake/blinker curcuit so I'm only using one wire for the running lights and one for brake/blinker? I just cant figure out where the flasher needs to go. It seems like if i put it in the line side of the brake it would cause the brake lights to flash. | | |
#98154 11/19/2006 8:44 PM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Oh yeah, single bulb dual filament. '42GMC. Aftermarket lights. | | |
#98155 11/19/2006 8:48 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mmcdaniel69,
I'm not real clear on your question, but I will mention a few thoughts.
Each BRAKE light will need a wire from the turn signal device.
The power goes through the brake switch, which is activated when you step on the pedal. From the brake switch, the power would go to the turn signal device, and if no turn was indicated, would travel through the two wire to each brake light, which would illuminate to show a STOP.
If it were, say a left turn, the turn signal mechanism would 'blink' the power for the left light, but the right light would illuminate uninterrupted.
In the conventional system, three wires would be needed. One wire for both TAILLIGHTS, one wire for left BRAKE/TURN and one for right BRAKE/TURN.
The flasher will go between the brake light switch and the two wires going back to the brake lights.
I'm not sure this answers your question, but it is a general layout of how it should work.
Stuart | | |
#98156 11/19/2006 9:49 PM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | atomarc
Sorry, I meant three wires one for tail and one each for brake/blinker
OK, so the flasher goes in, between the brake light switch and the turn signal device?
I'll need to run a power wire from the fused source to the brake light switch through the flasher, then to the Turn signal device, or visa versa.
If it goes to the brake switch first how do the blinkers work without hitting the brakes? Is there a seperate source to the turn signal device?
Also how do the front blinkers keep from getting power when the brake pedal is depressed?
Hope I haven't confused you as much as I've confused myself!
Thanks. | | |
#98157 11/19/2006 10:36 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mmcdaniel69, You are absolutely correct...I forgot about turn only power. Before I confuse you any more, take a look at the link I enclosed. Lots of the magic takes place inside the turn signal switch itself, so some of your questions should be answered when you study the picture. http://www.film.queensu.ca/CJ3B/Tech/SignalWiring.html Stuart | | |
#98158 11/19/2006 10:50 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A '42 GMC didn't come with a turn signal switch, and there was more than one approach to adding turn signals.
So the right answer might be different depending on your turn signal switch. What switch are you dealing with? Five wires or seven?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#98159 11/20/2006 2:50 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | I'm not sure if I'll be using a 5 or 7 wire switch.From the look of the diagrams probably a seven, but I can see it will be made easy by purchasing an aftermarket switch.
Thanks guys, Mike. | | |
#98160 11/21/2006 12:03 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need a 7-8 wire switch. If you buy the after market switch it will have a wireing diagram & is pretty easy. It is difficult to figure out without a diagram. It seems each brand uses different color sceme. The flasher goes to the hot feed wire of the switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98161 11/21/2006 1:24 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Hey Jim.(Carolines truck) Your mailbox was full. I think something may be missing from the pm you sent,either that or I'm missing something-VERY POSSIBLE!  Hey, by the way where is Grass Valley? Thanks, Mike. | | |
#98162 11/21/2006 4:02 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you can use for LED lights
i have a tech article on it's way to peggy now about how to do this
one light w/ two functions
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#98163 12/06/2006 8:43 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | What year truck? How many tail lamps do you have? How many bulbs in each lamp? Was your truck equiped from the factory with turn signals? If the tail lamps have 2 bulbs each, are they 2 element or single element bulbs?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#98164 12/17/2006 6:38 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | '42, 2 tail lamps, 1 bulb each lamp and no, not originally equipped. It looks like a 7 wire aftermarket turn signal switch is going to be the ticket. Thanks for all the information. | | |
