2 members (Rusty Rod, porsche), 64 guests, and 3 robots.
Topics128,021
Posts1,055,357
Members48,420
Page 1 of 2 1 2
#980682 10/23/2013 1:51 PM
can anyone tell me what these numbers are. i cannot find them anywhere.
block on top 3836850 GM3
con 4 j 190
ser# 21ksa 1183
on plate by distributor SC 425
bottom front of motor 3788950
any help would be appreciated. don't know if motor is 216 or 235. maybe thats why i cannot find these #
jimbo 24 #980684 10/23/2013 2:00 PM
What dose the valve cover look like. Dose it have two bolts coming though the top of it. If it dose its a 216. What year of truck is it?
jimbo 24 #980725 10/23/2013 4:10 PM
3B Offline
Hy jimbo 24, I could not find that exact block casting number over at the Inliners International site, but I did find 3733950 which is a 54-55 261, is it possible that what you thought were 8S were 3s, hope that helps.
jimbo 24 #980780 10/23/2013 7:52 PM
1952 chevy 1 ton 9 ft. bed
jimbo 24 #980792 10/23/2013 8:28 PM
jimbo 24 #980793 10/23/2013 8:29 PM
first 7 pics
jimbo 24 #980860 10/24/2013 12:30 AM
It looks to me like you have full pressure 235 engine cast Oct 19 1960 to fit a 1954 Chev. It has the high mount water pump last used in 1954.
My Blog
jimbo 24 #980884 10/24/2013 1:09 AM
u mean it's not original motor for 1952 1 ton
jimbo 24 #980894 10/24/2013 1:39 AM
ser# is 21KSA 1183. what truck do i have. i am so confused
jimbo 24 #980896 10/24/2013 1:44 AM
Jim,
Looks to me like you have a 261...
Block 3733950 = 54-55 ALL (261) (1st Ser.,)
Head 3836850 = 54-62 ALL (261).
The date code J 190...J = Month, 19 = Day, 0 = Year (1960)
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
jimbo 24 #980897 10/24/2013 1:48 AM
you say you have a '52, apparently someone has changed the engine in the last 60 years, what's the confusion??
jimbo 24 #980900 10/24/2013 1:56 AM
Jim,
Here's your serial number breakdown...
21KSA 1183
21 = Janesville Plant
KS = 1952 3800 1 ton
A = January
1183 = Unit number starting wit 1001, so you have the 183rd 3800 out of Plant 21.
Hope this helps,
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
jimbo 24 #980906 10/24/2013 2:08 AM
thank u. so this is a 1960 truck
jimbo 24 #980909 10/24/2013 2:14 AM
confusion is someone says 235 engine and others say 261 i am lost sorry
jimbo 24 #980910 10/24/2013 2:16 AM
NO, see the note above KS = 1952.
You have a 1952 truck with a 1960 engine transplanted into it...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
jimbo 24 #980911 10/24/2013 2:16 AM
?? thought you said it was a '52? the engine year has nothing to do with the vehicle year, does it look like a 60's series truck or an Advance Design truck?
jimbo 24 #980913 10/24/2013 2:21 AM
I get all of my info from GM books...I don't post answers to questios I can't back up. Who says it's a 235 and what are they basing their statement on?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
jimbo 24 #980917 10/24/2013 2:28 AM
look at some response to my post
jimbo 24 #980918 10/24/2013 2:29 AM
bill looks like ad truck to me
jimbo 24 #980920 10/24/2013 2:34 AM
jimbo 24 #980926 10/24/2013 2:45 AM
The valve cover with the center fill hole is like the one on my 53 with powerglide engine that has a 56 848 head on it. My point is, you need the stamped code behind the distributor to know what block you have. Someone can add all kinds of stuff to mislead you.
jimbo 24 #980927 10/24/2013 2:45 AM
I don't think the water pump is the critical ID point .... trust Mike, you have a '52 truck with a '60 261, lucky you
jimbo 24 #980957 10/24/2013 3:53 AM
The water pump design not matching the casting date is important if you are buying parts.
As I said before that pump design was last used in 1954 on cars and 1955 first in trucks.
This is a crate engine.
Engines I have seen like this are put together with date of assembly(1960 in this case) parts, even though it looks like a 1954 engine.
That means it will have tang main bearings, and the oil pan rail will bulge out on the pass side. The oil pump will also be different than a 1954/55 1st.
My Blog
jimbo 24 #981036 10/24/2013 2:28 PM
carl do u mean sc 425 by distributor
jimbo 24 #981139 10/24/2013 10:30 PM
jimbo,
You posted above that SC 425 was on a plate? "on plate by distributor SC 425"
Carl is referring to the engine serial number that is pressed into the block in the ledge just to the rear of where the distributor goes into the block.
If you have a factory replacement engine, that code might be odd. Depending on state laws and the practice of the installer, a state defined code might be there, or the code on the former/original engine might have been put there (or, any off code might be there).
As you most likely know, the engine serial number was one of the commonly used codes for titling/registering a vehicle. This causes problems when the engine is replaced.
Nonetheless, as Carl asked, what code is pressed into your block to the rear of the distributor?
jimbo 24 #981152 10/24/2013 11:34 PM
sc425 and maybe another 5. thi can see pressed into the block. also that C could be a 0 hard to tell
Mike B #1033404 06/04/2014 6:38 PM
here r a few pics. i am working on engine and don't know what engine i have mike says its a 261 1960. guy from jim carter says its a 54 or 55 235 or 261. can i get some help[IMG]http://i1296.photobucket.com/albums/ag3/cuz2424/truckrngine006_zps94bec366.jpg[/IMG]
jimbo 24 #1033405 06/04/2014 6:40 PM
jimbo 24 #1033406 06/04/2014 6:43 PM
jimbo 24 #1033410 06/04/2014 7:07 PM
jimbo 24 #1033411 06/04/2014 7:12 PM
I think some/most of this information/interpretation is also posted above:
3733950 : 1955-2nd through 1957 261 block casting code
3836850 : 261 head casting code used all years
What is the complete code pressed into the block just to the rear of where the distributor goes into the block (can you post a link to a photo)?
Also, what are the block date casting code and the head date casting code?
"sc425 and maybe another 5. thi can see pressed into the block. also that C could be a 0 hard to tell"
sc425 maybe sc4245 maybe S04245 maybe S04245S maybe F0425S
S 04 25 5?
S 04 25 S?
F = Flint, MI
04 = April
25 = 25th
S = big truck with 261
Your water pump is a 54/55st style (it extends above the top of the block), but it might have a relocation plate?
It is possible you have a 1963+ replacement block/head. If it is, it is the third I have seen (heard-of). Maybe Greg_H will chime in - WD Foster gave him information about these.
If it is a replacement block/head, the date casting codes might be interesting. And, the engine serial number is a "replacement" code that might have been stamped incorrectly/oddly.
This might be a guessing game.
jimbo 24 #1033499 06/05/2014 2:57 AM
Are there captain's bars above the starter and on the opposite side of the block?
jimbo 24 #1033537 06/05/2014 4:06 AM
no captain bars on either side
jimbo 24 #1033538 06/05/2014 4:13 AM
all the numbers on block by distributor either sc425 or so425 they are plain to see but no other numbers
jimbo 24 #1033663 06/05/2014 4:48 PM
any more help
jimbo 24 #1033778 06/06/2014 2:41 AM
The captains bars on both sides would indicate a 261. The lack of captains bars, I am not sure. Someone with more knowledge than me will surely respond soon.
jimbo 24 #1033818 06/06/2014 5:02 AM
thanks carl
jimbo 24 #1033852 06/06/2014 12:47 PM
My guess (WAG) is that it is a post-1962 GM replacement block, which could be machined after casting for use with a 54/55st or post 55st water pump.
It would be interesting to pull the head and see if there are the six extra coolant passages needed/used on a 261 block.
If my WAG is correct: CON 4 J190
CON 4 = Conveyor 4
J = October
19 = 19th
0 = 1970
This would be the third such GM replacement block that I have seen/hear-of.
Dave (Pre '68 Dave), what is your guess?
tclederman #1033890 06/06/2014 4:38 PM
jimbo 24 #1033891 06/06/2014 4:42 PM
my pics
con12 and on other side K300
Page 1 of 2 1 2
