| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Whats the difference on the length of the generators. I have found there is two lengths of 12 volt generators for the 50s Chevrolets. I am suspecting that it is a differences in amperage. Can anyone shed some light on this?
Thanks in advance Walt Williams La Verkin, UT
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I installed a Police generator on my '61 Lincoln that has more output then the stock one. It was longer, I assume to have more coil windings, to produce more?.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The longer gen. can put out more amps. The regulator needs to match it or be set up to take advantage of it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | 45 and 55 amp generators were used on Buick, Oldsmobile, Cadillac, and some Pontiac applications. I don't believe Chevy 6 cylinders were equipped with anything above 35 amp, but with a longer mounting bracket and a correct regulator the high-output generator could be retro-fitted. Jerry
