2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | I was working on building a cab dolly today. I made a frame that bolted to the 4 cab mount locations. I was thinking of making it so I could tilt it towards the firewall and roll it around that way as well, so the back of the cab is up, making it easier to work on underneath. What I'm not sure of is how long to make the legs. If the cab is too low it will be hard to work on...too high might not be good either. Anybody have any experience with this?
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | OOOPS
I'm going to move this over to body and paint
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Check out the cab dolly instructions in the Tech Tips pages.
Drew
| | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | yeah, I did. Those look more like storage dollies. Too low and no access to the bottom. I was looking for ideas on a 'work on it' dolly so you can get to the cab corners and underneath.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well, the cabs are pretty strong, so just flipping one on its nose gets access to the bottom. It's been done many times from what I've read on Stovebolt.
Drew
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Check out the flp it dolly on 67-72Chevy trucks forum. I think his name is Kevin, sells plans. You might be able to get an idea from his. Good luck . Jim | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | A futon frame with appliance casters worked beauty for me. See here.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | great idea ! very nice truck by the way, love that color.
Killer body work too. Did you do that yourself?
thanks, Greg
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Made one from a 4x4, 2x4's and four casters. Set height at two foot high. Made long enough to roll cab on back to clean and paint bottom. Whole thing was less than $50 bucks. Works great. Sorry no pic.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
