4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
Whats the difference on the length of the generators. I have found there is two lengths of 12 volt generators for the 50s Chevrolets. I am suspecting that it is a differences in amperage. Can anyone shed some light on this?
Thanks in advance
Walt Williams
La Verkin, UT
8
8 Offline
I installed a Police generator on my '61 Lincoln that has more output then the stock one. It was longer, I assume to have more coil windings, to produce more?.
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Riding in the Passing Lane
The longer gen. can put out more amps. The regulator needs to match it or be set up to take advantage of it.
1972 Chevy c10 Cheyenne Super
45 and 55 amp generators were used on Buick, Oldsmobile, Cadillac, and some Pontiac applications. I don't believe Chevy 6 cylinders were equipped with anything above 35 amp, but with a longer mounting bracket and a correct regulator the high-output generator could be retro-fitted.
