| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | HI List,
I need a regulator for my 55.1 half ton and although I find a lot of similar ones on ebay, the part number is a few digits off. As long as I get a 6 volt regulator are they all the same? For example if I find a 1118827 out of a 1 ton will it work?
Joe
1955 First Series 3100
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | while various regulators are rated for 6v (or 12V) they do vary in the amount of current they allow before cut-off. Basically they are matched to the generator. if you use a different regulator than intended, get one with a lower current limit than your generator can deliver, otherwise you risk overloading and burning out your generator. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Joe, When choosing a regulator it needs to be matched up with the generator. In your case if your using the original generator, Delco #1102793 it was built for a potential output of 45 amps. give or take. Most of the time they would put out well over that if allowed. This generator would have been used on 1st production 55s. The 1118843 is a 6 volt regulator and rated for a max. output setting at 41-47 amps. The 1118827 is a 6 volt regulator and has the same amperage output setting of 41-47 amps. Basically the same regulator. If you went with a regulator of a lower rating your generator would still charge just not what its capacity would be. 25 amp regulator will only let your gen. charge max. 25 amps. This is why its important to match up your generator and regulator. Just FYI, the second production 55s using any of the several 12 volt generators available had a drastic reduction in amperage output compared to the 6 volt generator. Even the optional power steering generator #1102041 was only good for 30-35 amps. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Collector Auto Supply - phone # 800-414-4462 has Regulator # 1118843
Llewllyn Obsolete - phone # 818-363-5094 has Regulator # 1118827
Make sure they are Delco Remy NOS .
I'm sure you can also obtain aftermarket regulators
equivalent to your oem regulator.
George in New Jersey
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Sorry, need to correct myself....53-1st production 55 was 1100018 and not 1102793. #1102793 was for larger trucks, 1 1/2 ton and up. Both still 45 amp and 6 volt but different generators. Either regulator would work for either application. The change in generators probably prompted the change in regulator numbers.
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Parts Geek on the internet http://www.partsgeek.com/catalog/1955/chevrolet/truck/engine_electrical/voltage_regulator.htmlshows a new regulator for GM Generator # 1100028 @ $55.35 I've never done business with Parts Geek. So, I know nothing about them. This took all of ( 60 ) seconds to find. The point is that you can find a new regulator for your particular generator easily. What # generator do you have ? George | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | those one size fits all (in any environment) tend to not work as well as the original manufacturer's part. I wanted to get a genuine Delco and there are a lot of them on ebay with a lot of different part numbers, Kennethw steered me in the right direction and I bought a NOS Delco unit on ebay that has a slightly less max current than the 111843 but should work just fine.
Joe
P.S. I cannot be sure which generator I have and it has no tag. I just know its six volt
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Some more 1954 generator/regulator trivia: A new low cut-in generator #1100028 (40 amp) replaced generator #1100018 (45 amp) in late 1954. Voltage regulator #1118843 for gen #1100028 Voltage regulator #1118827 for gen #1100018 Full page view of info that George posted: > 1954 Chevrolet Service News - March 1954 p11 of 12> 1954 Chevrolet Specifications 12-18-53 - Trucks> Gen 1100028 for 3000 series, 1954 FAM 12-7.01> VR #1118843 for 3000 series, 1954 FAM 12-5.00> 1954 Shop Man does not show Gen 1100028 Probably printed in 1953. "Late 1954" is at least after Feb 22, 1954 > Gen that George bought (1954 Feb 22)> Tim Lederman's '54 gen (1954 Apr 9)RPO Generators available for series 3000 trucks in 1954: $70.00 RPO #326B 55 Amp, Normal Cut-in (Not used w/314 Auto Trans) $70.00 RPO #326D 55 Amp, Normal Cut-in (Used w/314 Auto Trans) $75.00 RPO #326G 55 Amp, Low Cut-in (Used w/314 Auto Trans) $20.00 RPO #326H 40 Amp $21.00 RPO #326J 50 Amp, Normal Cut-in (Not used w/314 Auto Trans) $21.00 RPO #326K 50 Amp, Normal Cut-in (Used w/314 Auto Trans) $75.00 RPO #326L 55 Amp, Low Cut-in (Not used w/314 Auto Trans) $ 7.00 RPO #326T 45 Amp More gen/reg info from National Service Data > 1954 Corvette> 1954 Chev trucks p.153> 1954 Chev trucks p.154> 1954 Chev passenger cars> Manuals on RestoreCars{dot}com- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks Lonnie,
Interesting stuff,
What is the significance of a low cut in vs normal?
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Joe - I'm talking outta my ear on this one, so take it with a grain of salt. Other 'Bolters with real experience can give you the correct info. A low cut-in generator starts charging at a lower speed. More specifically, it starts producing a voltage equal to that of a fully charged battery. The armature is wound to produce current at low RPM's and a second winding to produce current at higher RPM's. The output amperage is lower in order to keep from having to increase the size of the armature and generator case by a large amount. The voltage regulator is designed and adjusted to match the low cut-in generator. I don't know if 1100018 and 1100028 are physically different on the outside. The '29-'57 MPC shows the overall length of both is 9-1/2 inches. > '29-'57 MPCBy the way, Ken Warner "Kennethw" at ClassicGenerator built the generator that is on my truck. He wound it for 12v and matched a regulator to it. They work great and look new. The 12v regulator does not have the screws through the top of the cover. I replaced the blank VR cover with a Delco-Remy cover that I bought on Stovebolt. - Lonnie
