| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | I'm in the process of painting the hood of my old 46' The side plates of the hood have the locking mechanism on them. If I remove the locking mechanism by drilling out the rivets is there a fastener available to replace the rivets that looks presentable? Thank you. Jim-
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Your question depends on what you are trying to achieve with your truck. 100% authentic restoration requires going back with a rivet of exact match to original. otherwise, machine screw lock washer and nut works great. I plan to bolt my hood halves back together in lieu of riveting. Spot welds will be puddle welded. | | |
