| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Has anyone seen or built a bed side spare tire carrier for a 57-59 mod 36 with 8 lug rims? I would like that on mine. It has the 16x6-8 rims. I have looked at the 1/2 ton ones for 6 lug and would they fit if modified? Pic would be appreciated Thanks | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | I did it! In my case I took like reference the 6lug carrier and made the new one adapting the base to 8 lugs. I´m not use the 6 lug carrier, just copy it. alfonso | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Thank you, Did you use the 6 lug rods and make a new plate or bend new rods to make the support.I am starting from scratch and wondered if a 6 lug carrier could be modified.
