4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#978366 10/13/2013 4:43 PM
I am new to this site so bear with me. I have a 40 chev pu and a 64 chev pu. I ordered a ps adapter kit from cpp and it says to use a 72-87 truck steering box. My question is- can a steering box from a mid 70's camaro or fb work? What is the difference? Is it the spline at the rag joint? Or is the box just larger?
Riding in the Passing Lane
The difference is which side of the frame it mounts on.
Also 80 up use O-ring type fittings & the earlier ones use fared fittings on the hose connections.
1972 Chevy c10 Cheyenne Super
Thanks for the reply. the 64 box is on the outside. I understand what you are saying. The camaros are probably all on the inside of the frame.
Next question. It is my understanding that only the 2wd steering box can be used. Does anyone know what is different on the 4wd box? thanks.
