1 members (Gray_Ghost),
87
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 114 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 114 | I looked in my shop manual and it says that the rear axles in the 3/4 ton and the 1 ton trucks are the same, but I can't find anywhere which axle it is. I need a new pinion seal and the autoparts store is asking whether it is a H033, H035, H052, H072, or Spicer 45. I don't which it is. Any help would be appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy kjhibbs, according to my Bower brg/National seal catalog, the seal should be a National 411330N, hope that helps. | | | | | Joined: Jul 2011 Posts: 114 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 114 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If it's the stock axle KJ it will be an Eaton HO52.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
