4 members (Spikeytop, Wayne67vert, 1955 1 Series, Otto Skorzeny), 101 guests, and 5 robots.
Topics128,181
Posts1,057,191
Members48,465
Would anyone know if there is someone out there that makes the headlight harness for a 46' with the original color coded cloth wires? Thank you.
Jim-
Try
http://www.riwire.com/
http://www.ynzyesterdaysparts.com/
Those are just two, very pricey
I believe road island will sell the cloth wire in color combo you want if you want to try to make the headlight harness yourself
Ex Hall Monitor
Ex Hall Monitor
YNZ sells the wire and terminals separately if you want to make your own. That's where I got my harness. As Dad noted it's pricey but worth it if you're wanting to keep the original look.
i got mine for my 46 1/2 ton from american classic truck parts..... not cloth but nice cover... and color coded, and everything plugged right up, came with all the numbered wires and instructions on where they go..... americanclassic.com
Thanks guys for all your help. With your references I did decide on a vendor to purchase the harness from.
Jim-
