4 members (Donf, Steelonsteel, Stovebolt48, TUTS 59), 74 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#977034 10/07/2013 3:31 PM
There are 3 different types of hydraulic lifters in my 56 235 pass engine. I want them to all be the same. Should there be a bleed hole in the rod seat or not? Most of mine have no bleed hole.I believe the ones with the holes are replacements. I can make the necessary cut on the plunger as explained on the forums. I just need to know which ones are original.
Thanks.
cassie #977035 10/07/2013 3:54 PM
1 Offline
This sounds like a Major Disaster waiting to happen. I think you should find out what cam you have and start with either all new rods and mechanical lifters or all new hydraulic lifters. Just my opinion, more knowledgeable engine help will be along shortly. Jerry
cassie #977044 10/07/2013 4:41 PM
There is no concern with mixed lifters.
Originally there would have not been a vent hole in the pushrod seat.
If these are in a running engine you run a risk of a flat cam by changing them. It is best to keep the lifters in the positions where they have worn into the cam.
My Blog
cassie #977050 10/07/2013 5:08 PM
I suspect the 4 replacements have only been in the engine a short time(maybe a year or so of infrequent driving) being as they looked new and came out easy. I have 4 of the original style ( not from this engine) so I thought it would be better to put them in in place of the replacements. The engine ran fine but had lifter noise even when hot.(lash was adjusted).I believe the older lifters were sticky with varnish. All have been cleaned.
Your thoughts would be appreciated.
cassie #977051 10/07/2013 5:25 PM
When you say you have 4 of the original style, are they used?
You never want to put used lifters on any cam lobe that they are not worn in to.
My Blog
cassie #977056 10/07/2013 5:43 PM
They are used.
cassie #977103 10/07/2013 9:13 PM
You can get lifters refaced but I would retry the ones you have cleaned. I hope you kept them in order as to where they came out.
My Blog
cassie #977252 10/08/2013 2:14 PM
Thanks. I did keep them in order so I will put all three types back in. Hopefully the cleaning will reduce the noise. I did your modifications to allow air to escape.
cassie #977280 10/08/2013 4:10 PM
I can almost guarantee they will be fine.
Let us know how it turns out.
My Blog
cassie #978842 10/15/2013 5:23 PM
Runs nice and smooth and quiet after warming up! Only one engine problem remaining. The distributor moves around a lot when running causing the timing to be erratic when checking it with a timing light. The distributor has been apart and gone over. I did not see much wear or play. Bent shaft? Any ideas? Not the type of movement caused by the vacuum advance. Kind of an off center "rolling" movement. Thanks.
