| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | I would like to change out my 1 ton 8 lug front spindles for 5 lug will that work or do I need to change out the entire axle? Also would like to know if there is a rear axle that will bolt in place of the 1 ton? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | spindles don't have lugs, hubs have the lugs ... the car 5 lug hubs will fit the 1/2T spindles, which are different than the 3/4T & up spindles, so you'd hafta find out if 1/2T spindles will fit the 1T axle
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...so you'd hafta find out if 1/2T spindles will fit the 1T axle
Bill Nope, very different size. | | |
