3 members (Peggy M, Deegs53, moparguy), 59 guests, and 5 robots.
Topics128,129
Posts1,056,700
Members48,454
Is an 11 inch clutch big enough for a two ton truck? My truck was recently overloaded and I ended up burning out the clutch at the landfill. The two speed rear end is stuck in high, which didn't help. I went in to replace it and was surprised to find that it was only an 11 inch clutch with 6 bolts holding down the pressure plate. I was expecting a 12 or 14 inch clutch. I suspected the engine and tranny had been swapped and ran the casting number on the block (3769925) and came up with a 59' 261 engine. At least it's a truck engine, but I still think the clutch is too small. Am I correct in thinking this?
Glory Bound...
manual says 11", 13" for biggest trucks
Thanks for that info.
Glory Bound...
If he has a 261 is 11" the largest clutch that fits?
Those bigger model trucks would have a V8 with a larger flywheel to fit a 13" clutch right?
•1952 Chevrolet 3800 pickup
---All pictures---
M Online: Content
The 261 was the standard issue engine for the 6000 series trucks in 1957, the 283 V8 was optional.
The clutch was an 11" diaphram spring with a 11"coil spring type optional.
The 13" clutch was only used on the 9000 and 10000 series 2-1/2 ton trucks.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike, what engines came with the 13" clutch? I don't know but suspect it won't fit on the normal 235 and 261 flywheel or in the bell housing? Wouldn't be surprised if there were a larger heavy duty flywheel and bellhousing, I just haven't heard of it for the Chevy 6 cyl.
---All pictures---
M Online: Content
Grigg,
The 13" clutch in 1956/57 was used with the 322 Nail Head only, it was the only engine available in the 9000 & 10000 series trucks. All of the smaller series trucks had true Chevrolet engines.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike.
So as I suspected 11" is the "big" clutch for a stove bolt 6.
---All pictures---
M Online: Content
The 11" Clutch with the Coil Spring Pressure Plate is the "big" set-up for the 6's and V8's...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
