| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | How easy, or difficult is it to replace the rear main seal on a 261 without removing the crank? A friend of mine said it will probably have a rope material seal that can be removed by carefully screwing in a wood screw into the material, careful not to scratch the crank, turn the crank and pull on the screw at the same time. And that a modern rubber seal will slip right in. Has anyone ever tried this or similar methods?
Glory Bound...
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have 1959 261 and have the rubber seal on it. I replaced it when the engine was rebuilt.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I got a good tip on this site: When you put the neoprene seal in rotate it just a bit so the ends don't line up with the bearing cap. That helps keep the seal effective cause the greatest path way out is blocked. Not too hard and it has worked for my 235 which was leaking bad. Now it is dry as could be for the last 600 plus miles.
Steve H
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If there is a rope seal in it, it could be tough to get out. I have put a neoprene seal in a 194 (230 250 family) with the crankshaft in place with no problems. The first one I ruined because I let the back of the seal rub on the edge of the block and it carved a hunk out of it. On the next try I kept it compressed a little as it passed the edge of the block. | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Just an update. I had no problems removing the old rope seal. Whoever installed it left one side a little long, which is recommended by Fel-Pro. I simply grabbed it with a pair of needle nose pliers and out it came. I was equally successful in installing the new Neoprene seal. won't know for a couple of weeks if it worked though. Wish me luck.
Glory Bound...
| | | | | Joined: Mar 2012 Posts: 12 New Guy | | New Guy Joined: Mar 2012 Posts: 12 | That is how I have done a bunch-you ought to be just fine, Well done! | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Reviving this old thread to ask a question:
It has been so long since I rebuilt my 261- can you get the rear main cap off and replace the seal without pulling the flywheel?
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2014 Posts: 4,483 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,483 | Yes, it will come off with the flywheel in place. If you drop the crankshaft, please remember to also remove your harmonic balancer. It will give you some room for the crank to go down without damaging the timing cover seal.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Thanks Jon….I’m not going to drop the crank- it’s just my rear seal is leaking, so just a seal replacement. I was so careful installing the first one (engine has about 100 miles on it now), any tips on getting it to seal better this time? I’m pretty sure I installed a neoprene seal in it.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2014 Posts: 4,483 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,483 | Dave, we've been discussing this on another post with a gentleman who is currently rebuilding his 235. With the neoprene seal (or the rope seal either) it is important for your crank surface (the part riding against the seal) to be as smooth as possible. If yours is that way, then it tells me your seal may not be making good contact with the crank surface. About the only way I've found to solve that is to cut some shim pieces from self-adhesive foil (the kind the HVAC folks use) to pull it closer to the crank a bit. When you remove your old seal you might want to compare it end to end with a new one. That way you'll know if your crank is too rough. If so it will wear the seal down just like rubbing sandpaper on it. Good luck!
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | How bad is it leaking, Norcal? If it's just a small amount, I'd call it normal and forget about it.
1950 Chevrolet 3100 (Ol' Roy)
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Otto, It is more than a seep- it is dripping out while driving and then making about a 5 - 6 inch wide flat spot on my floor after a drive. I’m concerned it might end up contaminating my clutch disc over time.
