| | | Forums66 Topics128,130 Posts1,056,717 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Is an 11 inch clutch big enough for a two ton truck? My truck was recently overloaded and I ended up burning out the clutch at the landfill. The two speed rear end is stuck in high, which didn't help. I went in to replace it and was surprised to find that it was only an 11 inch clutch with 6 bolts holding down the pressure plate. I was expecting a 12 or 14 inch clutch. I suspected the engine and tranny had been swapped and ran the casting number on the block (3769925) and came up with a 59' 261 engine. At least it's a truck engine, but I still think the clutch is too small. Am I correct in thinking this?
Glory Bound...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | manual says 11", 13" for biggest trucks Bill | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 |
Glory Bound...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If he has a 261 is 11" the largest clutch that fits? Those bigger model trucks would have a V8 with a larger flywheel to fit a 13" clutch right? | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | The 261 was the standard issue engine for the 6000 series trucks in 1957, the 283 V8 was optional. The clutch was an 11" diaphram spring with a 11"coil spring type optional. The 13" clutch was only used on the 9000 and 10000 series 2-1/2 ton trucks. Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Mike, what engines came with the 13" clutch? I don't know but suspect it won't fit on the normal 235 and 261 flywheel or in the bell housing? Wouldn't be surprised if there were a larger heavy duty flywheel and bellhousing, I just haven't heard of it for the Chevy 6 cyl.
| | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Grigg, The 13" clutch in 1956/57 was used with the 322 Nail Head only, it was the only engine available in the 9000 & 10000 series trucks. All of the smaller series trucks had true Chevrolet engines. Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks Mike. So as I suspected 11" is the "big" clutch for a stove bolt 6. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | The 11" Clutch with the Coil Spring Pressure Plate is the "big" set-up for the 6's and V8's... Mike B  | | |
