2 members (baldeagle, Oswald), 42 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#974068 09/24/2013 1:41 PM
finally got the correct size rivets and rollers for my window regulators.
the issue is that the new rivets require a setting tool similar to the one used to set the rivets on the vent window.
the window rivet is 5/16 i'm not so sure the vent window tool is big enough to do the job.
does anyone have a suggestion or "field expediant" method for setting the 5/16 window regulator rivet
rolf
1963 c10
rgie #974345 09/25/2013 11:35 AM
I made sure the rivet was opened up a little more (I used a nail set/punch) and made sure it was solidly supported underneath, then I used the Set tool/punch I got with the vent window kit.
Give me ambiguity
or give me something else
CASO #974515 09/26/2013 8:43 AM
i'll give it a shot
thanks
rolf
1963 c10
rgie #974525 09/26/2013 9:30 AM
Take a look here Rolf, should clear up your dilemma.
http://www.pbase.com/dennygraham/1950_doors
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
rgie #976032 10/02/2013 3:03 PM
thanks denny
never would have thought of that
rolf
1963 c10
rgie #979358 10/17/2013 7:00 PM
worked like a champ
not having a press, i used a ball pean hammer.
thanks again guys
1963 c10
rgie #981747 10/27/2013 3:01 PM
Ahh, a hand press Rolf, good enough. The trick is the ball.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
