| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97430 10/02/2006 6:23 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Just got my 1938 HC running. New 235 ('54 model) converted to 12V. Turn signals and modern conviences. I am using a GM 12V alternator and looking for help on how to connect it to the eletrical system. I re-wired the truck myself and everything works great. The alternator has a large threaded terminal on the back side and two blade type terminals recessed into the housing on top of the unit. What to I need to hook up where? | | |
#97431 10/02/2006 6:53 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to do a search because this has been discussed dozens of times. You'll also need to know which way the two terminals are oriented to determine what alternator you have. | | |
#97432 10/02/2006 7:09 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | lobo49, As Cletis mentioned, this subject has been discussed many times. This doesn't mean it is less important each time it is brought up, but it requires quite a detailed 'how to' description. If you can do a search using the little icon at the top of the page...maybe use the phrase " alternator wiring" or such, you will learn a whole lot. Then you can come back with specific questions. There are some very good schematics in the archives that show exactly how it is done. These will pop up in your search. You seem very knowledgeable about wiring, so maybe one of the wiring diagrams you find will answer all your questions. Stuart | | |
#97433 10/02/2006 7:29 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Wow is this alternator mounth already? Seem it was just yesterday that it was here. Oh, it was day before yesterday, nevermind. Go to tech. tips on this site and look it up. If you have any question after that. SOUND OFF!!!
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#97434 10/02/2006 9:00 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Thanks gys for your direction. I'm fairly new to Stovebolts, having cut my teeth on Model "A"s. But once you wear a BOWTIE, you'll never go back!. | | |
#97435 10/08/2006 7:36 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Looking at the back of the alternater the blade terminal that is counter clockwise to the other goes to the accessory side of the ignition switch. The other one is jumpered to the terminal on the back which also has a 10 guage wire that runs through your ammeter to the battery. If your alternater has a tiny #1 and #2 beside the slot with the blade terminals then #1 goes to accessory and #2 to the terminal on the back. Many of the early switches don't have an accessory terminal and so you have to use the ignition terminal. In this case you have to put a diode in the wire to the #1 blade or else your engine won't stop running with the switch in the off position.
Evan
#97436 10/08/2006 4:20 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see ALL of these links you can also go to search and just type in under electrical ----- alternator. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002234#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002217#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002186#000000 >> http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001966#000000 >> http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001857#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#97437 10/08/2006 5:59 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Lobo49, received your private message and was instructed to reply through forum. My shop is so far in the sticks it wastes half a morning or afternoon to go after a part so here's what we do for the needed diode. Take a junk GM alternater, internal or external regulater makes no difference, and punch out several diodes. You can see some of from the back of the housing--about 2/3's the size of a dime. After it's out and the lead is snipped take a test light and find which way it lets current pass. Put the test light clip on the negative battery post and touch first the "can" end of the diode to the positive post with the test light probe touching the snipped off lead. If it lights the flow is from the can to the lead and visa versa if it doesn't. Double check by touching the lead to the post and probing the can end. (I suspect diry minds are at work). Once the flow direction is found solder a lead to the can with a minimum of heat and cool immediately, then check again. Now install so the electrical flow is TOWARDS the alternater. This will let the alternater excite but not backfeed into the ignition. Tape off the diode since it is "hot". The wire will have a bump like a snake that's swallowed a rat but it works everytime. If you live somewhere near civilization you can go to a generater/starter/ alternater rebuild shop and get diodes, they have bins of them. I used to go to Radio Shack but the last trip there was told they no longer stock component parts--a shame.
Evan
#97438 10/08/2006 6:05 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | coilover, Very ingenious. I guess living in the sticks can lead to all kinds of creativity. Stuart | | |
#97439 10/08/2006 7:26 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Tnx. have visited all the links suggested. Have a source for components (resistors, etc.) Just need to now what size/rating diode to get. I understand the anode/cathode orientation for proper flow, but just need a suggestion as to what "size" diode. | | |
#97440 10/08/2006 9:18 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | lobo49,
I found this...it is a quote from another site!
One diode, something like a 1N4001, available from Radio Shack. This is rated at 50V and 1 amp.
This number has been mentioned before on this forum...pretty small and quite inexpensive!
Stuart | | |
#97441 10/08/2006 11:19 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Tnx Stuart. I think we are on track now to put this effort to rest. Von | | |
