0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97328 09/23/2006 10:47 AM | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | So I have been told that if you dont have the Ratio? A mismatched pulley ratio and alternator will be no good at idle speeds the alternator RPM is not necessarily the same as engine RPM the ratio between the two pulleys diameters. I was going to get the alternator today and they asked me what ratio. Is this true??
I have a 235 and I want to generat at lest 24 Amps. I will be runing 24 Amps of Commercial refrigeration so I was going to go with a 200 Amp alternator and 5000W Power Inverter With Battery Charger that will give me 30 Amps. Is this the best way to go??
all of your replies and feed back will be of help Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#97329 09/23/2006 10:19 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use a small pulley on an alternator. High RPM doesn,t hurt them. About 60 amps is all you could pull on a 235 the way the belt is. You will probably have to get a generator like the motor homes use for the kind of power you are talking about. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
