| | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I swapped a T-5 for the original transmission in my '42 1/2 ton but now it appears I can't use the original brake/clutch set up. The mounting bracket for the 235 hits the side of the T-5. What have you guys done to fix this problem? Can I rework the bracket or do I have to go with a different set up? If so what works the best? I thought this swap was pretty straight forward...whew! | | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I think what you need to do is cut off the bolt bosses off the side of the bracket to where it is a smooth surface. That is what I had to do. Look up Cavebull from the "user list" at the top of this bar. He is around page 19 when you alphabetize the list. His photo journal has a t5 swap with great pics. You will see what I mean. | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Wow this is fantastic. Thanks so much for the lead. People on stovebolt are awesome!! | | |
