3 members (TUTS 59, Jon G, Joe H), 97 guests, and 3 robots.
Topics128,026
Posts1,055,402
Members48,422
#972083 09/16/2013 6:56 PM
Has anyone used detailing clay or other mildly abrasive means (rubbing compounds) to clean the paint surface? I feel like there is a small amount of over-spray or grit on some of the surfaces on my truck. They are not visible but the paint is not entirely smooth to the touch.
Here is a link to what I found on AutoGeek
Auto Geek Detailing Clay
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
I've used a clay bar on mine. At first, I was skeptical about whether they actually worked, but was pleasantly surprised at the results. I was also shocked at just how much crap was still on the paint, even though the truck had just been washed and even buffed out with rubbing compound.
Bill Burmeister
razor blade helps too
Redryder pix
My Hotrod
I think I'll steer away from the razor blade, but more inclined to try the detailing clay.
Bob
Bethesda, MD
Clay takes a lot of elbow grease. But ya can't beat it. Never bothered on my primered 65 but I've done my work truck lol. I also use an oscillating buffer when I'm done to make sure it's all good.
Ritchie 54 #972161 09/17/2013 12:38 AM
Run your hand over the paint before and after - big difference !
Not that hard if you use lots of water.
1940 Chevy KC 1/2-Ton
a good detail shop will use clay, razor blade to get off over spray....watched them do it on my truck, thought the guy was crazy but he knew what he was doing....
Redryder pix
My Hotrod
Ritchie 54 #973461 09/21/2013 10:02 PM
Gas Pumper
Gas Pumper
So just a thought here... you run this clay bar over your paint and you pick up lotsa non paint crud. So you continue to rub this clay bar over your paint and you don't expect to have deep scratches from the crud the claybar picked up?
I am not opposed to it, just curious as to how big a problem this is?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
