7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 12 New Guy | | New Guy Joined: Jan 2012 Posts: 12 | Good afternoon folks. I had my Single Barrel Rochester Carb rebuilt. It idles fine but when driving i have to pull the choke about 1/4 out otherwise it backfires a little and is sluggish. Any ideas?
Owner of a long awaited 1951 Chevy 3100 Pickup
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like the float level is too low. If they rebuilt yours it should have the same jets that was in it. If it was exchanged for a "reman" its hard to tell what you have. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Check the float just like Wenchbender Ret said. If it still hesitates then turn the air mix screw out about 1/2 turn. If that helps you are just a bit lean at idle and a little richer helps the transition. It will not help the gas mileage but it will drive better. If you have one, put a vacuum gauge, on the intake manifold and set the idle with the vacuum gauge. Set to Max vacuum at about 450 RPM. Then watch the vacuum advance and move the throttle a bit. Advance should move. If it does then you should be good to go. If the advance won't move it is not working. Don't plug the vacuum gauge to the line for the vacuum advance it won't tell you what you need at that place. Use the manifold vacuum port where some wiper motors were hooked up. That is not the best place for the wiper motor but I have seen lots hooked to that port.
Steve H
| | | | | Joined: Jan 2012 Posts: 12 New Guy | | New Guy Joined: Jan 2012 Posts: 12 | Thanks guys. i will try that next weekend.
