| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | 1948 Loadmaster 1.5ton single speed rear end. I need a new Lock, bearing adjusting nut. #2 in my photo.. Does anyone know where to get one, new or used? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Take it to a good auto parts store and see if they have it. I'd call it a rear spindle nut, might help in your search, as you know bearing lock nut is also a good name.. Also look at some 4x4 front spindle nuts, may be some interchange. With part in hand and if you know the thread size and pitch I expect you have no trouble finding it new Try this, page 4-67 http://truckhub.us/yahoo_site_admin/assets/docs/Euclid100DWheelAttachingPartsX-Ref.96161249.pdfGrigg
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Check these guys out; http://www.quad4x4.com/gm10.5r.html#gmIf you have the HO72 rearend, the 73-81 GM 14 bolt spindle nut kit is probably what you'll need.
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thank You so much Grigg, and Whitedog! I took my part to Six States Distributing this morning before I had seen Griggs response. The guy showed me what he said was their closest match, however it was not close enough. After looking at the Euclid part suggested E4873 on page 4-67, I looked at Six States www they had the Euclid number linked to a part number 36636. I went back dealt with the same guy, who when he opened the box exclaimed that sure looks like it! It was a match! Needless to say without the input from the people on the Stovebolt forum I would be screwed! Thanks again! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Excellent, glad you found it. | | |
