| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Greetings all
Would the axle shafts from a 47-50 1/2 ton pickup work in a 51-54 pickup? I think I read somewhere that the differentials were different in some manner but I am seeking to make sure of that before I buy anything.
Thanks in advance Walt Williams La Verkin, UT
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Walt, As you probably know, 1947-1950 are different from 1951-1957 (and, I'd guess through 1959). However, they are all the same length and have the same number of splines. Go back a page in the book and find a different length 47-50 1/2 ton rear axle? Maybe someone knows the answer. Are there stamped numbers on your axle? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | When Chev went to Bendix brakes in 1951 they reduced the brake drum pilot size on the end of the axle. 1951-61 axles all interchange.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Why were there 2 sizes/parts for 47-50 1/2 tons?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are left and right axles, and they are different lengths. Is that what you are asking Tim?
Maybe in my earlier post I should have said 1951-61 axles all interchange on there matching side.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | How much did they reduce the pilot size for the brake drums?
I have an opportunity to acquire 2 NOS axles, R & L. If there not too large perhaps they could be machined down.
Walt | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Do they actually locate the drum or do the studs? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | How much did they reduce the pilot size for the brake drums? Walt Huck pilot diameter: 3.875" Bendix 3.550" I am sure the lugs would hold the drum close but they are held perfect by the center pilot.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Thats not that much. I think I will purchase the axles and have them machined down.
Thanks Walt Williams | | |
