1 members (MikeE),
70
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I've been yanking and pulling and twisting, but the knob for the headlight control just won't come of shaft. Any suggestions would be appreciated.
thanks
Is rust considered a body style?
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Behind the dash on the top of the light switch, there's a hole. You need to push a pin in it then you can pull the knob and rod out.
Does anyone have a picture for ??? (no NAME in profile?) must be hiding something??? hee hee.
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Denny posted a great picture! There should be a little knob/button on the side of the switch behind the dash, push it in and pull the light knob/rod out! Mine took a lot of finagling but I eventually got it out! | | |
