0 members (),
202
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | when turning over engine neg side of batt gets hot. have cleaned all connections. is this a sign starter going bad?? would a not new batt show this symptom?? thanks | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | rwb: You might have a broken post inside the battery. That is a very bed thing. Try another battery just to see if it gets hot on that side. If not, replace that battery. I have had one with a bad post explode in my face. Not something I care to do ever again. Heat in one part of a battery means there is a lot of resistance and inside the battery that is never good.
Steve H
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I had one blow up on me, too. About 40 years ago, very scary. Fortunately, I was an invincible teenager then, so no permanent damage.
I second the recommendation to try another battery. If that solves the problem, scrap the bad battery to prevent the chance of it being used.
regards, Leon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rwb,
What is the size of your negative ground cable from the factory to the frame?
| | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | As far as size, I go as big as the auto supplier has, too small a cable you have cranking problems, do it with both cables and your starting system will be happy. Pat
1966 Chevy C 30 1 ton truck
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Many auto suppliers stock 12v cables (4 gauge cables), especially for ground cables (and braided ground straps). It is prudent to be sure to use 2 gauge or thicker positive and negative cables (and ground straps) on 6v vehicles.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your post is confusing. On the heading it says the cable is getting hot & in the scrip it is the battery. You don't say if it is 6 or 12 volts. If the cable itself gets hot the cable is too small in wire gauge, like TC says. If the term. is hot then there is corrosion between the cable end & bat post. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
