2 members (PAUL Berardi, carbking), 160 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#969949 09/07/2013 12:12 PM
rwb
Offline
when turning over engine neg side of batt gets hot.
have cleaned all connections.
is this a sign starter going bad?? would a not new batt show this symptom??
thanks
rwb: You might have a broken post inside the battery. That is a very bed thing. Try another battery just to see if it gets hot on that side. If not, replace that battery. I have had one with a bad post explode in my face. Not something I care to do ever again. Heat in one part of a battery means there is a lot of resistance and inside the battery that is never good.
Steve H
I had one blow up on me, too.
About 40 years ago, very scary.
Fortunately, I was an invincible teenager then, so no permanent damage.
I second the recommendation to try another battery.
If that solves the problem, scrap the bad battery to prevent the chance of it being used.
regards,
Leon
rwb,
What is the size of your negative ground cable from the factory to the frame?
As far as size, I go as big as the auto supplier has, too small a cable you have cranking problems, do it with both cables and your starting system will be happy. Pat
1966 Chevy C 30 1 ton truck
Many auto suppliers stock 12v cables (4 gauge cables), especially for ground cables (and braided ground straps). It is prudent to be sure to use 2 gauge or thicker positive and negative cables (and ground straps) on 6v vehicles.
Riding in the Passing Lane
Your post is confusing. On the heading it says the cable is getting hot & in the scrip it is the battery. You don't say if it is 6 or 12 volts. If the cable itself gets hot the cable is too small in wire gauge, like TC says. If the term. is hot then there is corrosion between the cable end & bat post.
1972 Chevy c10 Cheyenne Super
