1 members (moparguy),
39
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 19 Junior Member | | Junior Member Joined: Mar 2003 Posts: 19 | I recently purchased a 1953 3100 equipped with a 235. The original owner said the engine was stock but the casting numbers show that the engine was built between 54-57. Is it possible that the dealership put this engine in? Also I need help matching up the water pump and the generator pulleys. They are both 3/8 inch pulleys but they are offset by about 1/4 to 3/8 of an inch. This is causing excessive vibration and noise from the wobbling of the water pump. Will a long shaft generator compensate for this? Any help would be appreciated. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Welcome to the Stovebolt I would imagine that the bracket the generator is mounted to may be incorrect or someonehas installed a different generator at some point. Do you have any pics you can post links to?
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If you had a 53-4 motor the pulley on the waterpump is pressed on and cant be changed easily. If you have a 53-4 motor the waterpump will be higher on the block with a plate behind it and on the 55-62 blocks the waterpump is lower in the block and the impeller is in the block. To give you advise on what to do on the pulleys the year of block must be known but if its a 53-4 someone might have had the crank pulley off and not in all the way or had the waterpump rebuilt and the pulley is not in the right place. You might have the wrong generator on it also,take a ruler or straight edge and see whats not lining up. If someone put in a 55-62 motor they might have shortened the waterpump and dont have the hub on right or the wrong pulley. If thats the case you need to contact jim carters or patricks and get a shortened pump with pulley. I hope this helps | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | heyhowyadoing, Can you see casting number on the block almost being covered by the starter ? They may be something like
B262
This would tell you what year your enjun' is...
The above number is mine which is Feb 26, 1962
ciao'
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I believe there is a 1/4" spacer that goes between the front of the generator mounting bracket ( the one under the generator that bolts to the block ), and the back of the generator end frame.
I'm helping a fellow bolter with a '48 truck that has a '58-'62 235 in it and is equipped with a 6-volt, long frame (10-1/2" overall length) generator. It has a generator mounting bracket of 6-1/8" overall length and requires a 1/4" spacer in front of the bracket and a 1/2" spacer in back of the bracket to match up to the generator end frames. This truck has 3/8" pulleys.
I also have a '38 truck with a '48 216 in it with a 12-volt generator with is also 10-1/2" overall length. It has a homemade generator mounting bracket of 6-1/8" length and matches the factory bracket on my friends '48 truck. It has the same set of spacers on it. This truck has 5/8" pulleys.
If the water pump pulley and the crank pulley are in line then you probably need the 1/4" spacer on the generator.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Another thing that can be done to correct the gen alignment is to slot the holes in the mounting bracket that bolt to the block. The upper arm can bolt onto the front or back of the gen, iirc. It can also be shimmed to match. Running with offset pulleys will destroy the bearings in the gen and the pump. As for the engine being original, I wouldn't bet any money on it. Some of us old folks tend to forget things.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Easy ways to date engine:
'53-55 engine had generator bolted to oil pan rail casting of engine block. '55-62 had gen mounts on side of block just above oil pan rail casting.
'53-55 Used a 4" water pump pulley '55-62 used a 7" water pump pulley
Engine block casting date is cast into block above starter, just to the right of the CON4 cast into block. A-L is month, two digits is day, last digit is year of decade cast. For example: A154 would be Jan 15,1954. L040 would be Dec 4, 1960.
'53-55 had straight oil pan rails, the '55-62 pan rail sort of 'doglegs out' as it goes toward the back of the block.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
