2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
jwc
Offline
I cracked the driver side window. Got a nice big spider running thru it.
Have removed the widow, and now need a replacement. Local shop wants $145.00. May have to find another local place. Some of the classic truck parts shops have windows for $29 - $37 dollars. Ecklers has a "replacement" window for $99.
Am not looking for show quality. Just want a window that fits, doesn't leak, whistle, or yellow. Any suggestions of universal vice replacement or one parts place over another?
JWC
Ecklers also has one for $38 .... flat glass is flat glass, try other local shops and if you can't find one that's not so proud of their cutting skill, go for the cheapest vendor, but also the closest, shipping will be spendy .... or you could try a post in the Parts Wanted for a good used piece
I had tempered glass made for my '54. 2 doors and back for about $ 150.00. Tempered won't crack.
Check with a few different shops, if they are cutting laminated, which is what you have, it shouldn't be more than $50.00.
Ecklers, Classic, etc mass produce them that's why they are cheaper but will charge you more for shipping.
The $99 door glass pieces at Ecklers include the metal "runner" channel/bar attached to the glass (and are assembled for left door use or right door use).
The less expensive door glass pieces at Ecklers ($38-$50, depending on color) are just the glass (and can be used on either side, with your runner channel/bar).
You will need to clean your metal channel and use glass-setting tape (or modern equivalent) to set the glass into your runner channel/bar.
jwc
Offline
Stovebolters -
Checked the local establishments. Local glass places would either have to order or do not cut laminate glass. One other place I found would charge $83 just for the glass & $30 to put in the channel.
At this point, am gonna order glass and tape from a classic parts place and tackle this project myself.
Thanks for assistance!
Joe
Sir Searchalot
Sir Searchalot
Yes, that's what you should do. It's not that hard. Work on a carpeted table top and read the tips in the tips section here and on the webernet.
Moderated by  ndkid275, Phak1
