My help made it down today, so we got on to installing the rear window. Had the gasket in for a few days. Used a glass suction handle on each side of the glass, soaped the channel real good, started the window in in a lower corner. Working both inside and out of the glass. After getting the bottom in, went up one side, across the top, and down the remaining side, lots of soap and the window was in. The bead was a little harder to get in, but it did go in with no problems. Looks great. Along with your good instruction, the rubber from Steele made a big difference also. Costs almost 3 times what the other did, but it was a better quality rubber and actually a little smaller looking into the end of the rubber. Thanks again for the info.
Jim
