| | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | In my 49 Pickup I changed my gears from 4.11 to 3.55 and I understand there is a adapter that I can put in the speedometer cable at the transmission to indicate the correct speed. Where can I buy one and how easy is it to install? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | $60 from Patricks for the different trans gear, not too technical a change Bill | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I ordered my adapter from Jim Carter's...oldchevytrucks.com. Give them some info from road testing your truck (explained on their website) and they will make one specifically for your set-up. | | |
