2 members (Gdads51, Jon G),
100
0
Mod | | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | I have a fuel pump plumbing question. 58 with 235 and double action fuel pump. My fuel pump has a connection from the tank (in). A connection to the carburetor (out). Below, left, engine side, a vacume connection that goes to the wiper motor. Below, left, fender side a connection with rubber tubing approx. 8" that is not connected to anything. Do any of you know what this is for. Also, the right mounting bolt has a nipple. Should something be connected to this? Thanks for yor help. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The unconnected goes to vacuum source (intake manifold) to operate wipers or more correctly "assist" on hills and acceleration. They were plumbed with a short hose then steel tubing. Nipple? As in where a hose connects or is it a grease zerk?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | The right side mounting bolt on the fuel pump is one piece. Threaded end , bolt head, with a stem for tubing. The manifold stem has tubing that goes through the firewall to the wiper motor as well. | | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Pictures please, I know I am having a hard time "Seeing" what you are trying to describe.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Brian Will get some help to post picture. The right side mounting bolt is hollow with a stem for a hose. Not sure where a hose from this stem would connect. Also, there are two stems on the left bottom. One of these has a short two inch rubber tube then steel line then rubber tubing that goes to the wiper motor. The 2nd stem has an approx. 8" piece of rubber tubing that is not attached to anything. I'm in the process of re-assembly after engine rebuild. Fuel pump worked fine as is before and wipers worked as well. The repair manual describes this bolt with reassembly instruction to re-attach hose. I have steel tubing going from the vacume advance on the distributor to the carb, and rubber tubing going from the manifold also to the wiper motor. Would appreciate any pictures of plumbing for a fuel pump like mine. Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The vacuum line from the intake manifold does not go to the wiper motor - it should go to one of the ports on the bottom of the dual-action fuel pump. Another line should run from the other port on the bottom of the fuel pump to the wiper motor.
You have a 50-50 chance of getting the port connections on the bottom right.
The ports might be labelled:
"Manifold" or "In" goes to the intake manifold vacuum port. (Might also be labelled "L1" or "1").
"Wiper" or "Out" goes to the wipeer motor (Might also be labelled "L2" or "1").
Are the ports on the bottom of the pump labelled?
| | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Thanks Tim. The bottom inside port is labeled in. The connection goes along the side cover and to the wiper motor. The bottom outside port (out) has the 8" hose. Could this connect to the hollow mounting bolt stem? It's about the right length. | | |
