5 members (Niels V, Phak1, MNSmith, 2 invisible), 77 guests, and 4 robots.
Topics128,180
Posts1,057,141
Members48,463
Has anyone used this kit? What were your results?
So far I hooked up the drivers side to some 1986 Cadillac Seville brakes. It almost looks like I might have to make an extended bracket to attach to the E brake cross bar to get more throw.
Mark,I used them,nice easy install,they cut to fit as i'm sure you're aware,the only issue I had was the left rear caliper faces the back so had to route the conduit carefully but there's plenty of extra length to allow for this,not a problem if you're using drum brakes.... see here..
I've used a Gen 3 Pontiac rear with discs,once I got the brake calipers adjusted correctly it works just fine.
Just make sure the foot pedal plate 'bites' onto the pedal shaft well.
More pix on Flickr.
I have the Lokar brake kit in my 52 truck. I have a 9" Ford Torino with drum brakes and I hooked it up to the standard AD E-brake control ends. All I had to do was cut the cables to fit. Works great.
I have a feeling the Seville brakes are like my 88 IROC brakes. In that they need a full throw and I don't think I'm getting that on the current set up. Nothing that can't be fixed. Although, the calipers might just need a click or two.
I bought a set off Ebay awhile back. They worked out pretty good for me.
Robert C.
I'm a Genius in the making.
1950 3600
Thanks everyone for the comments!!
