| | | Forums66 Topics128,028 Posts1,055,413 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi List,
On my 235 exhaust manifold the pin that the heat riser spring hooks to is completely rusted away. Can someone kindly give me a diameter and exposed length of this pin so I can make another?
Thanks!
Joe
1955 First Series 3100
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Length is same as split pin that springs slides on to. Dia would based on the size of the hole after you drill out the manifold to remove the rusted pin.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Joe, Here is an over-sized-diameter shaft. It is not inexpensive, but it is set-up for the spring, the counterweight, and, I think, for attaching the flapper inside the exhaust manifold. If you get it, please let us know how well it works. I do not think that anyone has reported on this relatively newly listed item. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think you're referring to the pin that the spring hooks onto Joe. If that's the one then it's a 3/16" diameter pin with about 5/8" sticking out of the casting. How much is in the casting is anyone's guess. I would think 1/8" to 1/4" more would put it somewhere in the ball park.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks Denny, that is indeed the pin I was talking about.
Joe
