3 members (Nick in Manitou, Sjm, 1 invisible), 88 guests, and 4 robots.
Topics128,264
Posts1,058,356
Members48,485
#967567 08/28/2013 12:48 PM
Hi List,
On my 235 exhaust manifold the pin that the heat riser spring hooks to is completely rusted away. Can someone kindly give me a diameter and exposed length of this pin so I can make another?
Thanks!
Joe
1955 First Series 3100
F Online: Content
Length is same as split pin that springs slides on to. Dia would based on the size of the hole after you drill out the manifold to remove the rusted pin.
Ed
Joe,
Here is an over-sized-diameter shaft. It is not inexpensive, but it is set-up for the spring, the counterweight, and, I think, for attaching the flapper inside the exhaust manifold.
If you get it, please let us know how well it works. I do not think that anyone has reported on this relatively newly listed item.
I think you're referring to the pin that the spring hooks onto
Joe. If that's the one then it's a 3/16" diameter pin with
about 5/8" sticking out of the casting. How much is in the
casting is anyone's guess. I would think 1/8" to 1/4" more
would put it somewhere in the ball park.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Denny, that is indeed the pin I was talking about.
Joe
