5 members (Hotrod Lincoln, Gdads51, Gray_Ghost, David Bush, Gib70), 117 guests, and 0 robots.
Topics128,051
Posts1,055,735
#96734 08/18/2006 3:52 AM
Apprentice
Apprentice
I have a1966 chev truck with a 230. Right now I have plain jane dash. Fuel gauge and warning lights for amp, cold and oil. Would love to go to the dash with factory gauges. Getting the gauges no problem... Do i have to get a new wiring harness or not ???? Can I just hook up the factory gauges with my old harness.......
#96735 08/18/2006 4:19 AM
no,,harness is different,,you can add/subtract some wires or swap harnesses,,underdash + engine harnesses,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#96736 08/20/2006 7:38 PM
Apprentice
Apprentice
Do I need both under dash and engine harnesses. Or can I just wire the gauges separate. Not change the harness at all. What is the best ? ? ? I can not see why I can't wire them separate....
#96737 08/20/2006 10:18 PM
here is a site that may help,,I did this to mine-pulled the harness, untaped & added/pulled out required wires,,not hard but time consuming,, web page brian
