1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96620 08/08/2006 9:32 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | I ordered a 2 bbl conversioin from LAngdon's Stovebolt and also upgarded to the electric choke. THe stuff is waiting for me at our second house in TX. I'm excited to see and install the setup. How does electric choke install? What power source do I tap into, etc...
Any help is greatly appreciated!
Thanks, Steve
Today is the best day of my life!!!
#96621 08/08/2006 9:40 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
I think you want a source of power that is always ON when the key switch is in RUN...the truck is running. And welcome to the bolt!
Stuart | | |
#96622 08/08/2006 10:50 PM | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | If I remember right there are three screws holding on the water choke. You remove these, put on the electric, turn it to tension the spring according to the accompanying paperwork, put the screws back in, and tighten them down. I wired mine to the coil. | | |
