Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Bill Hanlon, 52Carl, ShopRag, Wickedbass, Hotrod Lincoln, 59 fleet, Otto Skorzeny), 53 guests, and 2 robots.
Topics128,009
Posts1,055,291
Members48,419
#965041 08/19/2013 12:35 PM
55.2 3100 235 Rochester B carb. With the air filter off, I can adjust the A/F screw out about 1 1/2 turns runs fine(idle). Put the air filter on it dies. With the air filter on I have to adjust the A/F screw all the way in to make it idle, and as soon as I take the air cleaner off it dies. Air filter is new, I even tried one of those cheapo chrome air cleaner filters, same deal. Truck drives down the road fine, starts fine, last trip I got 15 mpg, which I think is good. Any idea?
TIA.
Brian
Brian
1955.2 3100 Truck
55shaker #965042 08/19/2013 12:41 PM
What air filter are you running?
Give me ambiguity
or give me something else
55shaker #965045 08/19/2013 12:45 PM
Sir Searchalot
Sir Searchalot
Air filter pushing on choke or something on carb. Interfering with a cable or linkage or a butterfly or something is hitting the filter. Mechanical issue not air flow.
55shaker #965053 08/19/2013 1:15 PM
what bartamos says............when did this problem first start up. see if you are missing any beer caps...........just joking
Redryder pix
My Hotrod
55shaker #965061 08/19/2013 1:41 PM
I started to ask about air flow restriction in my first post but realized that the mechanics might be at play so limited my question to the basic info needed.
We still don't know what this "New" air filter is...
Has the carb recently been worked on?
Give me ambiguity
55shaker #965071 08/19/2013 2:14 PM
Sir Searchalot
Sir Searchalot
It does it with two different filters. Old and New. But you are right, would like to see pics of both of them installed and pics of them on the bench. On another note: If he puts air cleaner on , adjust carb and it starts fine, runs down the road fine, what's the problem? You don't take the air cleaner off while driving do you? If it ain't broke, fix it? It could just be that this carb/filter set up runs only when they are tuned together, that's OK! Semi-normal.
55shaker #965081 08/19/2013 3:40 PM
Riding in the Passing Lane
Check the float level. A high or low float level can cause problems like this.
1972 Chevy c10 Cheyenne Super
55shaker #965095 08/19/2013 4:31 PM
My air filter interferes a little with how the two cables work. When I have reinstalled the carb, I have had to fiddle with the cables to get around the problem.
1951 1 Ton Completed
truckernix #965202 08/19/2013 10:40 PM
http://s1184.photobucket.com/user/b...011-09-08140115.jpg.html?sort=6&o=28
This is the style air cleaner I have with a new Fram CA77 paper filter installed.---- With the choke open, and with the air cleaner base and filter installed, and the A/F mixture screw turned about 1 1/2 turns out it idles fine. As soon as I put the lid on top of the filter it dies.
Wrenchbender ret, this would be the carb I got off of you last Oct. Not complaining, just letting you know what I'm working with.
I'm in my sixtys and I never had a carb idle change that much on any engine I've had just by putting the air cleaner on after adjusting it.
Brian
1955.2 3100 Truck
55shaker #965218 08/19/2013 11:49 PM
Just a shot in the dark. If there is a vacuum leak, manifold, throttle shaft, or other, increasing the resistance on air entering the carb by adding the air cleaner may cause it to suck more air through the leak.
55shaker #965238 08/20/2013 1:29 AM
Sir Searchalot
Sir Searchalot
You are correct Shaker, it should not change idle too much, just some. The big question now is when did you put on the Carb and when did you notice all this? Did you just put it on after a year or did you just rebuild carb? What is the recent history here???
55shaker #965240 08/20/2013 1:45 AM
Shaker: Very different cable clamp than I have. But I don't think that is the problem. Metal mesh filter is very much like the filter I have with out the "basket" or "can" that I have. With just the diameter difference for air flow. With that said I have never had to adjust my air/fuel mix after putting the filter back on. I can't imagine that changes the air flow that much. Try pushing the cables aside with out the air filter in place and see what happens. I think you will see the choke butterfly move. And then you can figure out why. Just a guess of course but that is what I would try. Look for any leaks of course but I think this is mechanical. If I can figure how to post some pics I will tomorrow.
Steve H
55shaker #965242 08/20/2013 2:00 AM
Bart it's been on since spring. It's probably been messing up for a couple of months now, and I just getting around to talking about it. With the air cleaner off it idles good. 20" vacuum and a steady needle. Carb has not been rebuilt since I had it, but looked like it could have been before I got it.
Steve, like I said with the base of the air cleaner on with the filter it idles fine, and you can see that the choke is open. Just setting the lid on will kill the engine, and the choke cable isn't being touched when I do this. I don't have the throttle cable installed yet.
Brian
1955.2 3100 Truck
55shaker #965247 08/20/2013 2:50 AM
So at 'normal' atmospheric conditions (no cleaner) it runs normally at normal (1 1/2 turns out) setting. Carb works as intended.
Put a nylon brillo pad over your mouth and breath. Next try a paper towel or three. If you can tell a difference I'd guess it's about the amount of fuel you need to reduce ("all the way in") to get to the ratio needed to combust when the new paper air filter is added.
Give me ambiguity
55shaker #965254 08/20/2013 6:16 AM
From your description of putting the lid on, the filter must be affecting the air flow.
55shaker #965269 08/20/2013 8:57 AM
Brian, the Fram filter that your using instead of the wire mesh
spark arrestor is made for a much, much smaller engine. There
isn't enough surface area with a small paper filter so it
chokes it down. Replace the paper filter with the old wire mesh
and you shouldn't have any problems. If you're really concerned
with getting clean air to the engine then look for an oil bath
air cleaner that will fit that carb.
http://www.pbase.com/dennygraham/image/115069462/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
55shaker #965282 08/20/2013 9:31 AM
If you are correct, Denny, you win the "successful sleuth" prize of the day - good suggestion.
It is nice to see you posting more often. That oil-bath suggestion might get some interesting responses. Maybe someone will post a warning/belief that oil bath air cleaners are worthless (as has been posted recently). "if they are so good, why are they not used on modern vehicles?"
55shaker #965296 08/20/2013 11:35 AM
Denny, I had thoughts along the line of what you mentioned. But I can't grasp that there is that much restriction, for the small amount of air going through it at idle. But what you say makes sense, cause it runs fine till you put the lid on, and the all the air has to go through the filter. Big problem with a simple fix.
Brian
1955.2 3100 Truck
55shaker #965339 08/20/2013 2:33 PM
55 SHAKER: Try K&N website might have a filter about the same diameter that will flow enough and fit in your housing. Or try to find what Denny Graham posted. That is a good looking bath filter. The wire mesh you have must be clogged badly.
Steve H
55shaker #965379 08/20/2013 5:46 PM
Sir Searchalot
Sir Searchalot
The filter you tried is for a 58 Cu In Simca engine!!!!(as Denny says). Your engine is 4X larger. So I'm not up on AD filters but: Is this a dry filter with just mesh? Did you remove the mesh and put in the paper? Did you leave the mesh in and install the paper? Will your old canister only take this 7" x 3" paper filter? Did you clean the mesh out real, real good? The air filters I have seen that have spark arrestors in them also take a filter. Is yours a spark arrestor/filter mesh all in one or what? Is the mesh not a spark arrestor as some have said? It seems like everyone already knows all this but I would like to know also. Having trouble seeing what you have and what you have tried, so I can give an educated guess as to what is wrong or understand the good suggestions. Denny says just use the mesh, isn't that what you started with and does not work when lid is put on? If it was me I would start with an EMPTY old canister with the lid on to be sure of the mechanical then add the biggest quality paper that fits and see. I realize you said you fitted it all up without cover and it ran good until cover installed. Take out everything inside canister first for a baseline. This will prove that it's the air flow not the canister shape, size or a mechanical interference. You don't need a spark arrestor. They are for boats, forestry equipment and various state requirements for OHV's.
55shaker #965445 08/20/2013 8:29 PM
These trucks came stock with the "spark arrestor" Bart. The only
other option was the oil bath filter, which by the way was a
pretty good filter, not as good as the "properly sized" dry
filters in use today, but pretty good.
And you are correct Bart, the paper filters that replace the
wire mesh and fit in the "spark arrestor" housing are for lawn
equipment engines.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
55shaker #965450 08/20/2013 8:36 PM
Bartomos if you read his reply post on the first page he said it's a new paper filter which made me look again at the symptoms he described.
You say mesh filter I say Brillo pads and paper towels... It couldn't breath through the paper filter.
No AIR means less fuel and his need to adjust "All the way in".
Why people choose a certain filter over another and the issues that raises is the reason this place stays busy...
Do it this way... Try this?... Here's what I did...
Give me ambiguity
55shaker #965470 08/20/2013 9:03 PM
Sir Searchalot
Sir Searchalot
It's Bartamos. Yes he put a new paper filter in but did he take all the mesh out and try, because as Denny says it's too small of a surface area to begin with and having the dirty mesh in there with it is too much restriction. Somebody please tell me what is inside this stock air cleaner. Some mesh you call spark arrestor? an additional mesh filter? Combo mesh filter/arrestor? Do they typically get all gummed up? I wouldn't have that mesh on there if you paid me.
55shaker #965475 08/20/2013 9:07 PM
guess he did not have spell check..lol
I remember when folks would run without air filter because some thought the sound was cool..
Redryder pix
My Hotrod
55shaker #965478 08/20/2013 9:10 PM
Sir Searchalot
Sir Searchalot
It does sound cool. Like a pretend gasser. Joker, I know you are behind this. I've had two different guys spell it that way tonight.
55shaker #965497 08/20/2013 9:42 PM
probably like me, can't spell worth beans... now,you just met Jack and
you dont know him or me..lol
back on topic, here is the cure to the air cleaner problem
here is the cheap one I had on my 52, worked well for me, drove that booger many yrs ever where..no problems
now, dont make fun of it..........worked really good
Redryder pix
My Hotrod
55shaker #965506 08/20/2013 9:53 PM
My spell checker didn't catch it for some conspiratorial reason, sorry bout that BartAmos...
I wasn't really caring so much What made it act that way as Why it needed to be starved for fuel to run...blush
I run the original filter with the mesh. Mine is like a nylon brillo pad/mesh.
Also,I just had a lawn mower refuse to run on the dirty filter a week ago so I get where the need for air flow and one of those filters comes from not me
Give me ambiguity
55shaker #965510 08/20/2013 9:57 PM
Caso, you are so right.. I have seen lawn mowers not start because of a dirty filter and a truck run like crap because of one being dirty.
Redryder pix
My Hotrod
55shaker #965570 08/21/2013 1:07 AM
Sir Searchalot
Sir Searchalot
The mole is active, be careful. They are after me just like I predicted.
55shaker #965573 08/21/2013 1:38 AM
My air cleaner never had a spark arrestor or filter when I bought the truck. So when I got the truck together and running I just went to a flaps and found a paper filter that would fit. So with the help of my fellow stove bolters, and you too Denny. I've come to the conclusion that I have to come up with a better filtration system.---Thank you all for your help!!!!!!
Brian
Brian
1955.2 3100 Truck
55shaker #965612 08/21/2013 8:41 AM
Now.........after all this page after page of discussion, I
gotta come out of the closet and admit, that I've been running
a Car Quest 87373 paper filter in place of the stock mesh. The
87373 is made for the Kohler and Tecumseh 8 thru 16hp lawn
equipment, Had this filter in place since 2006, which amounts
to about 10,000 miles of driving on my stock 216.
Taint had any trouble with it and I've run the 'B' and a Carter
W-1 both over the years.
So.........where does that leave Brian? Back to square one???
And Bart, seems to be some cornfusion on your part as to what we
mean by "spark arrestor". That was the term that Chevrolet used
to describe the stock "air filter" that the 216-235 would have
come from the factory with. It refers to the whole unit, the
two piece housing with a wire mesh filter in between. This
whole thing is the "spark arrestor": http://www.pbase.com/dennygraham/image/121329450
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
55shaker #965676 08/21/2013 12:09 PM
I went out and looked at my other filter that did the same thing. And it's a CARQUEST #87373. frown
Brian
1955.2 3100 Truck
55shaker #965680 08/21/2013 12:25 PM
Sir Searchalot
Sir Searchalot
Thanks Denny. Shaker: If you tried the same thing as Denny is using and it won't run, then you are back to Square one. Square one is the carburetor, vacuum leak somewhere, choke getting sucked closed, float valve, etc. Boy if you had another carb to try, you would sure solve it quick. One day it seems like restricted air flow, the next day it seems like carb. Exhaust flapper OK? Return spring OK? check float level and drop.
55shaker #965686 08/21/2013 12:37 PM
easy fix, drive it without one for a few days,
if you have no problem then you know using
your filter is effecting it some way for sure..
Redryder pix
My Hotrod
55shaker #965898 08/22/2013 12:44 AM
It don't mess up now when I put the air filter on. I got me a 14" X 3" air filter mounted on there now with no change in vacuum reading when the filter is installed.
Brian
1955.2 3100 Truck
55shaker #965940 08/22/2013 9:12 AM
Thanks for the follow up Brian, to many find the problem and
never report back in.
Can't figure though why my 216 runs well and as you know I get
it out on the highway and run it a lot, like a trip to Princeton, via Dover.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
